The Eiffel Project
...so this is the final looking of the big structure laying on the second platform
Looking at the photos of the real thing I realized that this is not the exact shape of this construction, the actual building is less "square"... but I didn't want to spend more effort on this part that is enclosed inside the structure and not so well visible. I'll spend more work on the very top platform that will remain well visible not being covered by the beams.
Now, one last thing, the railing that runs around the platform. Here you'll see another self-harm exercise with microscopical lasercut pieces...
The difficult thing was not the cutting part... it was handling the pieces without destroying them... but the effort was worth it!
and after the paint job the result was really good!
So this is the completed second platform...
Now it's time to start the last big drawing session to complete the upper part of the tower main structure: very little details, increasingly thinner as you go up...
See you soon!
Hello my friends,
I'm here again with one of my crazy projects. This time will be a new kind of paper model trying to depict the Eiffel Tower in the best detailed way I'll be able to manage.
I was always fascinated by this great monument, the complex structure has always represented a challenge for a crazy modeler like me that I could not avoid to take.
Recently I was in Paris and, standing in front of those huge pylons I started to take a lot of photos... the idea was already growing in my mind...
Once returned home I talked of my idea to Nando (a virtual friend met here at Zealot who became a great friend in the real life that I meet everytime I am in Turin) and Nando talked me about a wonderful book about Tour Eiffel that I immediately ordered to Amazon. That book was originally published by Gustave Eiffel in 1900 and is a collection of many of the original drawings utilized for the building of the real thing. Even if you don't want to build the tower is such a pleasure for the eyes that should be in every bookshelf.
View attachment 227432View attachment 227433View attachment 227434
The documentation is OK, now let's talk about the model...
My idea is to merge some details realized with the usual papercrafting techniques and other cut with my laser engraver. There are many models of this subject around but everyone has to keep the detail level somewhat under a certain degree where the usual manual cutting would be impossible. I want to push my model above that level hoping that the result won't be too fragile to stand up...
The best Eiffel model around, in my opinion, is the Schreiber one. It offers the option to cut many of the apertures between the lattice and obtain a very good level of detail (take a look to the thread by @tino here at Zealot to have an idea). I started buying the Schreiber model and studying the build process of that model. Then I scanned every page and reduced to 80% as I don't have the space to keep a model more than 1 meter tall (my wife point her finger to the suitcases everytime I talk about building a new model, especially if it is a big one... I think this is a sort of subliminal message...) My tower will be "only" 80 centimeters tall...
Next phase: I started tracing on the scan every detail, every single beam, every rivet, to prepare the file I would later send to the laser. In the image you can see I used different colours to trace the lines. Every colour will be associated to a different laser mode. Some will be full thickness cut, other will be surface engraving, other will be area engraving... and so on.
Here is the first batch of lines traced on one of the first floor parts. The cut lines are the red ones. As you can see I would like to cut most of the details of the structure.
After some tries varying the laser parameters (mainly speed and power of the emitter) I determined the right program to send to the device for every kind of line previously traced.
And this is the first piece I realized to test the procedure...
It will be a long journey...
Looks like a model worth building. Me and my wife visited and went up into it in Paris a couple of years ago.
Reactions: Tonino
Here I am with a little update: the second platform.
This time the work to detail the sides was significantly easier, the shapes are simpler and not decorated.
obviously, remembering what happened with the first platform, I covered ALL the surfaces with smooth cardboard.
Once painted the piece is looking very good
Now let's turn to the second floor building... This time I wanted to hurt myself realizing all the windows frames (that are about 0,5 mm wide)...
The glass was simulated with a piece of plastic pasted with a generous amount of PVA glue that, once dried, become completely transparent.
Then I applied the upper row frames after having opened the windows in the cardboard.
...and placed other transparent plastic pieces from inside
and, eventually, I placed the lower row window frames over the plastic previously glued.
The level of detail is ASTOUNDING! Me thinks you took out a shrink ray to the actual Eiffel Towel and shrunk it to hand size.:biggrin:
I shall not allow anyone near it for the time being because I can already see a tiny Celine Dion the size of an ant standing behind the railing, singing "My Heart will go on" in a chipmunk voice...
:animated:
Hi guys!
Here I am with another little step toward sky
This time I've completed the first half of the upper (and last) section of the main structure.
First of all I realized the stairs that run in the center of the tower. I don't know if, now, there is an elevator instead of stairs, but I choose to remain close to the Schreiber model and traced (and cutted) the corresponding piece.
as always a photo taken with the light from behind make easier to appreciate all the cutting work
Then I realized a custom version of the intermediate station with its own balcony and microscopic railing
This is the "core" of the new section...
And now to another big tracing, tweaking, cutting and refining work...
As before the union of the various sections - to be done one at a time - must be perfectly orthogonal so I used extensively my custom jig. Below you see the lower sections already glued and the uppermost still to join. The one blocked with tape is the one currently setting (you can see the CA glue still fluid).
Prior to assembly all the parts of the structure I have to realize another little balcony above the second platform, it will run around the base of the upper section of the tower.
And this is how it appears once completed
This is the intermediate view point ...
...and this the complete section just finished
And... (I couldn't resist... I had to do it) an union test of all the finished sections... we are almost arrived at the top...
The next episode will be the last section of the main structure, then I will start the best part, the one that I can't wait to place the hands on, the very final one, the cherry on the cake...
They must have toilets up there, right, or is it constantly "yellow" raining, if you know what I mean. Just curious.
ASK AND ANSWER: YES!!
  • Haha
Reactions: Tonino
I can research a little to see if I can place some little toilet somewhere... just for completeness...
Wow, looks like a fantastic project. Me & my wife were actually there in the eifel tower back in 2024. The details on the model are pretty cool.
