Tunnel liner question?
trainsteve2435
487
barboursville, wv
Hello everyone, i know this has been asked before, but how is the easiest and cheapest way to create a tunnel liner? The section i need one is pretty big and i cant see makeing those plaster liners. It would take me a month just to cast enough of them. Has anyone out there made theirs a different way? Thanks!
steve:cry:
Do you mean the insides of a tunnel?
That's easy.. Take a section of PVC pipe (available at your local Home Depot) of the proper diameter, cut it to the length of the tunnel, then make a single cut lengthwise so you can spread it apart to seat alongside the roadbed. Voila!
I could be wrong but I don't see a reason to put liners all the way thru your tunnel. I've seen maybe the first 6 inches of either end and that's it. Unless you have a cut out to grab those derailed trains. :)
I hear the woodland scenic liners are really easy to use.
