Klarlack , Verniz transparente
JimmyXY
Well-Known Member
Jun 17, 2025
29
74
59
Hallo Freunde,ich hätte eine Frage.bei mir verblassen nach gewisser Zeit die Farben.Sollte ich Klarlack benutzen . Wenn ja,welchen empfehlt ihr ?.
ich danke euch und wünsche schönen Tag noch.
Olá amigos, eu teria uma pergunta.com eu depois de um certo tempo as cores fade.Deveria eu usar verniz claro. Se sim, o que você recomenda?
Agradeço-lhe e desejo-lhe um bom dia.
Hello friends, I would have a question.with me after a certain time the colors fade.Should I use clear lacquer . If so, what do you recommend?
I thank you and wish you a good day.
You may be using Dye Based Ink, which is not U.V. proof, and sunlight will cause your models to fade. You need to switch to a printer that uses "Pigment Ink" to have permanent colors, as Pigment Ink can last 100 years and considered archival..
