- Apr 5, 2013
- 14,503
- 11,177
I only use printers that use pigment Ink. The link below explains the differences well. The Inkjet printer below only uses Pigment Ink and with the CISS (Continuous Ink Supply System) you will get years supplies worth of ink, they are purchased separately. Top link is the printer. It's the model that matters, not where you get it from. Pigment Ink allows for water forming as it does not smudge.
Article link = https://splashjet-ink.com/dye-ink-vs-pigemnt-ink-the-differences/
Printer Link = https://www.walmart.com/ip/HP-Offic...9AE533EABEA5F73AACEE4B29&conditionGroupCode=1
CISS system from above printer (they recommend this printer) The CISS has bulk refill bottles you can buy to refill the CISS bottles system, an incredible saving that pays for itself if you use a lot of ink and print a lot.
Link = https://www.inkproducts.com/compati...for-hp-officejet-pro-8122e-8135e-8138e-8139e/
