- Apr 5, 2013
- 14,215
- 10,834
The translucent piece looks like a new version of the Borg sphere.![]()
Mine has vertices in the middle of each polygon. Or maybe you get from one to the other by making the Bucky ball pentagons bigger so that hexagons become triangles. I'm delighted with the results. I had a copy of a book about Buckminster Fuller, but I sold it. I didn't think I'd want to reference it again. He had some interesting ideas.Lizzie, none of this is boring. I've been waiting to see what you were working on. Looks like you have dialed it in. Kind of reminds me of a Buckminster Fuller geodesic sphere, or "Bucky Ball", yours is smoother, quite an accomplishment on your part, don't you think?
I will never forget the pictures 100's of students standing of fields with him trying this. I think your sphere is absolutely awesome!!Buckminster Fuller tried to show that on a cliff at sunset, demonstrating how, if you stood still and stretched your arms out and really concentrated, you could feel the earth move under your feet
Onward. I haven't posted in a awhile for fear you folks will be bored as I refine the design. I'd planned on painting the surface with acrylic or doing decoupage, but I've become fascinated with the structure. Every time I build I think I can do it better: simpler, fewer pieces of paper, easier to put together, cleaner construction. I still think I can cut it down by 10 sheets of paper and get it under 45 sheets. This will cut down on time to build as well. Right now its at 3 stand+10 frame+20 triangle units+1 light mount+12stringers+4 stringer+5 skin=55. I've found I can tape two sheet together to cut two parts at once in some cases. I've been eyeballing Glowforge as a way to get cutting done faster, but I don't want to buy the machine.
Here's the bunch of them. The front in the latest build. I might put a skin on it.
Here the are lit up. I need to order more lights. I also would like to try out a plug in light.
Different exposure.
This is with a second skin held on with poster putty so that the panels can be removed. I need to screw up my nerve and start drawing or painting on the panels.
This is the structure of the most recent. I've worked out the light access door which you can see on the top. It hinges open for battery or light replacement. The joins at the centers of the pentagons will be cleaner in the next go around. They take a bit of size adjustment to adapt to the thickness of the paper used in the interior structure. I suppose I could do it mathematically, but for me it seems to works best if I get in close mathematically then build and tweak the size.
If it's a government picture, and you are a U.S. citizen, you paid for that pic, so you can use it. You just have to leave the source on the pic, I believe. Your not charging for the pic, you charging for the Ball and putting the "free' pic on it!!!(I'm not a lawyer, but my understanding is that anything paid for by tax payers is open game).
If you could do a tutorial on how you made those triangles to put on that ball, I would be so appreciative.![]()
I just might do that.That's magnificent globe in the works!
Given the NASA material available, you could do the whole solar system; even the planet, eh, Pluto!!!![]()
... even the planet, eh, Pluto!!!![]()
