  More Bumpass  photos
 More Bumpass  photos
Bumpass  was  removed  from  my  RR  before  I  got  a  digital  camera,  and  With  film  cameras  I  did  not  document  my  RR  as  much  as  I  do  now,  as  it  wasn't  easy  to  share  the  photos.     Here  are  some  ancient  black  and  white  photos  of  Bumpass  that  I  have  found  and  scanned.
My  best  guess  these  photos  were  taken  in  My  folks  driveway  @  Timberlake  near  Meridian  Mississippi  in 1978 .
Bumpass  was  a  marvel  of  design  and  construction.  at  two  feet  by  six  feet  in  two  sections;  it  fit  into  it's  twelve  square  feet  a  passing  siding, a  station,  a  two  stall  engine  house,  a  log  loading  ramp,  a  switchback,  an  iron  furnace  and  an iron  mine.  with  room  for  a  creek  winding  through  it.   The  plywood  back  drops  allowed  the  two  halves  of  the  layout  to  be  assembled  into  a  2 foot  x 2 foot  by  3  foot  box  for  transport,  and  fit  neatly  into  my  pinto  wagon.
There  was  room  on  the  end  of  the  passing  siding  and  switchback leads    for  a  25 ton  shay  and  two  short  cars.    As  a  portable  RR  it  worked   well,  but  it  was  a  judgment  error,  however,  to  build  a  much  larger  RR  around  it.   It  might  have  worked  had  The  larger  RR  been  committed  to   very  small  power,  and  short  trains  made  up  of  small  cars,   but  I  built  a  big  Sawmill,  and  then  had  to  look  like  I  was  trying  to  feed  it.     You  can't  feed  a  double  band  saw  mill  with  trains  that  can  make  it  through  Bumpass,  it  just  can't  be  done.
The  track  work  in  Bumpass  needed  a  lot  of  work.  I  had  never  sealed  the  homasote  by  painting  it   before  putting  ties  down,  so  the   homasote  held  moisture,  and  spikes  would  rust  out in  five  or  ten  years,  so  continual  maintenance  was  needed.  The  benchwork  was  heavier  than  it  needed  to  be    half  of  Bumpass  could  be  handled  by  one  man;  but  when  it  was  bolted  into  it's  box  form  it  took  two  men  and  a  mule  to  move  it.    It would  have  been  a  lot  of  work  to  restore,  and  was  too  heavy  to  be  an  ideal  portable,  so  I  salvaged  all  I  could  and  put  it  on  the  burnpile.
If  I  am  forced  to  downsize,  I  will  consider  revisiting  the  Bumpass  concept.   I  have  toyed  with  the  idea  of  doing  something  like  it  in  On3,  or  something  more  expansive  in  HOn3.   It  is  very nice  to  have  something  like  Bumpass,  so  you  know  you  could  move  to  a  new  house,  and  have  a  fully  functioning   railroad  up  and  running  in  less  than  a  half  hour.
In  the  photo  that  shows   all  of  the   Bumpass  module  note  the  Toyota  truck  in  the  background.    Perry's  Gizzzard ,  now  the  oldest  portion  of  my  RR, was  built  to  fit  in  that  truck.
The  evil  voice  of  the  model  train  demons  keep  whispering  in  my  ear  Bumpass  was  designed  to  fit  in  a  pinto  wagon,  what  could  you  build  that  would  fit  in  the  back  of  your  Suburban!
Bill  Nelson
