Wiring LEDs to Atlas Switches
Play-Doh
357
Portland OR
Hey Folks
Does anyone know how to wire an LED to indicate an open or closed atlas switch machine? I would like to create a board with my yard that can tell me at a glance if a switch is open or closed.
Im not sure if this had been discussed before....I ran a search with no luck.
Any help you can supply would be great!
Thanks!
TJ
There are 2 threads in specific that I've learned the most about this from. I'm actually at the phase of my layout now that i'm wiring my control board :).
This one:
http://forum.zealotmodels.com/t150429/
and this one:
http://forum.zealotmodels.com/t115968/
The essence is you need a relay in the circuit w/ the turnout, and a resistor attached to the led on your board.
Hey Folks
Thanks!
TJ
Thanks for your help! That had all the info I would ever need and I know now what im going to do.
One more question though.
I know that Yellow LEDs that run on an average 1.0 to 2.5 volts. SO I have a two part question.
1) What type of resistors do I need? Where can I get them? Walthers?
2) When a resistor is listed as "5 volts" what does that mean. Does that mean 5 volts is all it can handle or that is what is resists the voltage to?
Thanks again!
TJ
Hey Play-Doh and Triplex,
Regarding Play-Doh's question:
"When a resistor is listed as "5 volts" what does that mean. Does that mean 5 volts is all it can handle or that is what is resists the voltage to?"
:confused:If I'm thinking right, resistor's are rated in watts they can handle and in denoted by the 4th colored band on the resistor.
:thumb: Joe
:cry: Opps, should have written resistors are rated in "ohms and watts" Ohms=resistance and watts=power (heat)
Btw, I'm not sure what walter's is listing, maybe one of the more electro members can shine some light on this subject.:cool:
I had the same issue w/ resistors!!! There are a few resistor calculators on the internet i used this one to convert from colors to resistance readings:
Resistor Color Code Converter
and this one to calculate what the resistace i need for a particular circuit:
The Best Current Limiting Resistor Calculator for Led's
So when i started i knew nothing (don't know much more than that now but ...) what i did was use the calculator on quickar's page to calculate the type of resistor i needed for all my leds if i powered them off my toy transformer i have screwed under my table, i chose 12 to 14v as the input voltage the other values i guessed at.
This whole resistor thing is still not that solid in my head but i managed to get the right ratings and bought a bunch from mouser, and a bunch of led's from quickar and i've been able to get them all working :0.
wall1 Sorry everyone. At dinner tonite I realized an earlier mistake I made. The 4th color of a resistor is the % of its value as stated by the color. The watts rating is determined by its phyiscal size.:p
So sorry, btw what do you use to remove the rust from the brain? :eek:
wall1 Joe
