Thanks everyone for the positive comments!
When it comes to tracks and suspension, my speed always slows down. The repetitive assembling is something I really struggle with — kind of ironic, since I enjoy building tanks.
Here you can see all the parts for the wheels, mounts, supporting rollers, drive sprockets, and tension wheels.
Because of summer vacations, it took me about a month and a half just to advance with the wheel mounts. The assembly wasn’t easy — not so much because of mistakes on my part, but mostly due to poor design.
Honestly, I don’t know what the designer was thinking… the drawings often don’t match what actually needs to be built. Wrong part thicknesses, incorrect sizes, inconsistent instructions — you name it.
Also, the instructions never mention that you need to build the mounts in a 4-on-4 symmetrical setup. And of course, there’s no guidance about the correct direction for attaching them to the hull.
So just a heads-up: make sure to build four mirrored pairs. As for the direction, I’ll come back to that later when I assemble the entire unit.
The rocker arm design especially looked suspicious, and I doubted it could handle the weight of the finished model. The axis rods were basically just a strip with two disks glued on, split into three parts.
At first, I followed the instructions and glued part 153g onto 1 mm cardboard. Logically, I thought I could overlap the strip for extra strength — but since the strip and part were the same diameter, overlapping caused a gap.
At that point, I decided to go my own way with a bit of scratch-building. I scrapped the disks, cut a strip of 80 g office paper, rolled it tightly on a toothpick, and used that as the main axis.
This roll fits inside the rocker arm and serves as a much sturdier base. Part of the rod was made using the same technique.
For the mount springs, I tested how many would fit properly between the rocker arms. In the end, I removed one of the largest springs plus three smaller ones to get a good fit.
Now the mounts are complete, and I’ll set them aside for a while. Next step is to assemble the drive sprockets (to get the correct wheel offset), then build the main wheels, and only after that glue everything — mounts and wheels — into place.
