Pz.Kpfw.IV Ausf.H, GPM 1:25
While I’m waiting for a friend to help paint the tracks, I’ve continued working on the model.
I started assembling the turret.
It has a simple shape and was straightforward to build.
The only adjustment needed was to the floor plate.
I also chose to laminate this part onto 0.5 mm cardboard rather than the recommended 1 mm, as it gave a better result.
As usual, the front plate was replaced with a Zimmerit version.
I have found that I cannot weld paper, it always catches fire!! Those are some really solid looking parts, and the joinery is fantastic. :)
  • Haha
Reactions: mijob and snake7
Thanks guys!
The next step was the gun itself.
The base is poorly designed — there are no clear instructions or drawings. To make it movable, you simply need to mount it on some kind of axle, but there are no markings indicating where to drill the holes, and no information about the axle’s length or diameter.
So I used some 1 mm wire and measured the length and hole positions myself. There was a risk that it wouldn’t move properly, but in the end it assembled well.
I’m not a big fan of long barrels — they’re difficult to roll and glue cleanly. I know the technique, but my experience hasn’t been great. This one was no exception. It bent slightly to one side, and I corrected it as best as I could. The final result is acceptable to me, but not perfect.
On the Sherman, I managed a much better result — probably because both the design and the paper quality were superior.
Another issue was with loading mechanism. I was in need to reglue shells basket much higher to fit it inside and have a clearance for gun to move up and down. So original markings were wrong.
Continuing with the turret toothed ring and the rear box.
The box has a unique shape, so you need to be careful during assembly and think in advance about the order in which the parts should be glued.
I started with parts 130 and 130b, then added 130d, followed by 130e, and finished with 130c.
The ring turned out to be too long, so first you need to measure the correct length and only then glue the ends together.
For now, I only glued the ring to the bottom of the turret and left the box for later, after I install the commander’s cupola.
I assembled the commander’s cupola.
As usual, the design is lacking in detail, so some experience is needed to glue all the rings together edge to edge.
The upper part of the visor shutters is a bit small, so I painted the visible space black to simulate the visor opening, as you can see in the photos.
Some parts of the hinge are odd, and the drawing wasn’t very clear, so I improvised — and eventually got a working hinge.
After gluing the cupola, I was able to attach the rear storage box.
I referenced real photos and decided to place the holding strips inside rather than glue them outside.
I tried putting the turret in place. It fits well, and now you can already see how the whole tank will look.
The hatch is open:
Thanks guys!
I continued working on the turret.
I assembled the side hatch doors, hooks, and the ventilation dome.
There is, however, a disappointing mistake that I couldn’t correct.
If you look at the hatch door drawings, the visor is shown on the left door and the shooting port on the right. But in the general side view drawings, they appear on the opposite sides — and even flipped.
After checking reference photos, I realized that the general drawing is correct, but the parts were designed according to the hatch detail drawing, which is wrong.
The obvious solution would be to swap the doors and place them on opposite sides of the turret. However, due to the camouflage pattern — which is specific and different for each door — this isn’t really possible.
At least the visors are oriented correctly...
Anyone not familiar with the original vehicle probably won’t notice, but I will.
Additionally, the hinges seem only partially designed. It’s not possible to make them functional, as only one side is provided and the strips are not usable. So I made a simplified representation of the hinges and left the doors open.
I’m starting to get a bit tired of these small design mistakes. The Panzer III from GPM had far fewer issues.
Hi all,
Continuing with the turret.
The last part was the turret floor.
Although the instructions suggest assembling the floor together with the supports, I found it much better to glue it in stages: first attach each support separately and then glue the floor onto them.
This is much more convenient than trying to align all three supports at once.
The whole unit fits nicely inside the hull.
Pay attention to how tight the fit is at the rear, where the storage box almost touches the bulge at the radiator access panel.
This is how the model looks now
The final step will be adding the Zimmerit protection plates around the tank, along with a few small details.
Still stuck with the unpainted tracks...
I instantly noticed the error!! Yeah, right, that model is not up to your standard. When finished, please send it to my address (PM me), and I will properly place it where it deserves to be, in an Argon Gas filled box for permanent preservation on my fireplace. ;)
  • Haha
Reactions: snake7 and mijob
