No Thats a GREAT IDEA I did use "Sawtooth" tabs. but that made one higher than the other.Have you tried joining the different parts with paper strips on the back side?
Thats it, Im doing this it sound PERFECT!!! it WILL work! Ill update...Just try it. You can use the excess paper / flesh / white / unused parts of the printed pages. For a test build I cut small strips and glue them to one edge so that about half of it is still visible. Then I cut into the visible pieces to create a sawtooth edge or just fringes. Then I apply glue to the fringes / tabs and attach the neighbouring shape.
I see!!!!! I will do that.It does look good. However, getting skin like this to turn out right is very difficult (at best). This is something that take quite a bit of practice to get right. However, what @Revell-Fan is indeed spot on. IF you can mate up the panels prior to laying them down onto the frame, you will have a much better outcome.
I SEE Thank you so freeking much!!!These pics will explain how to avoid accrued intolerance. 1st pic are two parts separated by strip (Red). 2nd Pic is a strip glued onto one side of the panel. 3rd Pic is parts together, with the strip on the bottom, made translucent so you could see the strip underneath. Only a line would appear on top.
