I continue to build. I prepared the safety dividers from accidentally turning on the toggle switches. I used a 0.4 mm steel wire wrapped around a 1 mm needle. then cut the dividers themselves. How many did, not count.
Some were leveled with pliers.
Then I made holes for their installation on super glue gel. I install with vertical alignment, so that later I do not correct or spoil the main part. This work will last long enough, since every detail has to be adjusted to fit the holes.
And the result
And the result
