Wiring Color Code
bentgen
13
www.billbentgen.com
Is there a convention for color coding wiring other than black/red for rail power? I'm aware that DCC wiring to a decoder is defined, but how about wiring to switch machines?
I've looked through the Atlas DCC & Wiring books but couldn't find an answer.
Thanks David.
N Scale Supply has a good selection of different colors in 3 different gauges. I'll probably go with orange, white, and yellow for switches to keep it distinct from the red and black for rail power.
AFAIK, there isn't any standard, so you set your own convention and just stick with it. I use multi-conductor alarm cable for both my rail blocking and turnouts so I'm limited to what they have in the cable. Two conductor is red and black, four conductor is red, black, green and white.
