What is this engine????
Gil Finn
Active Member
Aug 28, 2005
1,318
74
Bergoo W Va
I have a HO engine , blue and orange and lettersd for the Chicago & Eastern Ill.
It is a diesle made in Yugoslavia and labed Tympo.
This is stream lined looking .The horn is centered on the hood and on the side it has an outstanding curved fender running its lenth strating at the top behind the cab windows and running to the deck level at the rear.
Makes me think of an old studebaker.
ON the top are 4 exhaust fans.
The top looks like a F# and the hood sort of like a U Boat.
Maybe I can post a pic.
THese oix aren't very helpful but mayhaps someone can tell what this is and give me some data on it as a proto type.
It is very well made.
that engine is a BL2:thumb: , they were the first engines made by EMD, after the F unit body style. eastern, and small roads used them:thumb: . :D -Deano View attachment 31405
The BL1 and BL2 were basically F unit chassis with a new body to facilitate use in switching manuerers. The engineer couldn't see back of his unit because of the car body. The BL design was supposed to eliminate this enormous blind spot. While it had some initial success, it ultimately failed and the body design was replaced by the geep design that is now so familiar to us all.
Thanks you all.
I now learned this engine was part of a large lay out a fellow in MI had in 1966.
His house was robber and almost totaly cleaned out including his HO stuff. This engine was all that was left of his trains. His wife gave it to me.
Sometimes I like to copy colors of a RR and then also I like to make one up.
This may be somewhere in between.
I am matching it to a B unit for F3's
