Hi,
this problem might have 2 solutions. First, try to unroll a surface with a cut-in whole instead one with only lines on it. That way the lines stay where they are. Or second, in Rhino you should make it a common practice to rebuild curves, especially projected ones. Most curves can be described by 4 to 5 anchor points whilst projecting produces weird things. 'Rebuild' can be found under 'Curve tools'. Hope this helps
Regards
Jan
Regards
Jan
