Switched Scales, need specs.
Will_annand
Well, I decided to switch scales before I start my layout.
I just could not get that much into a 5' x 11.5' space. In N scale I can get much more.
I am attempting to design a new track plan. What I would like to know now is the specifications for N Scale.
1. What is the track guage in MM?
2. How long would a scale mile be?
3. What about inclines?
4. What is the spacing between tracks on the straight?
5. What is the spacing between tracks on a curve?
6. Anything else I need to know about N vs HO?
Any help would be appreciated.
1: 9mm
2: 33 feet (10.05831 M)
3: Inclines would be the same in any scale, h/r X 100 =%of grade, where h = the height, r = the run, or length in which the height was attained.
4: Ntrak spec is 1-1/2" (38.0997mm)
5: you can find specs at www.nmra.org/standards
6:you need to know OptiVisor......... :D :D :D
