Spur Question
hickstmj
Marcie
Jan 28, 2008
138
Florida Panhandle
I will be using blocks & two controllers for my track so two trains can run. The track plan I have does not isolate any of the spurs from the main line. Should I isolate them or is there a reason I should not isolate them?
Thank you
The positive:
-can store a complete train or locomotive in them if isolated
The negative:
-having to add the additional wires and block slider switch thingees.
I prefer every siding to be isolated.
If you were using a power routing turnout (such as Peco's electrofrog), it automatically handles it for you.
I second the motion. I've found that blocking the spurs has allowed operations to be a lot more interesting. A short local can hole up on a spur and I do use some for parking locos.
Ralph
