- Apr 5, 2013
- 13,959
- 10,377
- 228
Hey, on a misty day, you would see that "Haze" on the lights. It adds an ethereal look, like it is gaining a mind of it's own!!
This lighting looks SPECTACULAR!
I am wanting to add lights to a Thunder Fighter. I have been thinking of how I want to do it and what all I want to light and how.
Thanks R-B!
The one problem I have found, if you use high intensity LED's, is that the smaller you go in scale of the model, the light intensity becomes 'out of scale' to the model. It's just too bright. But, there are ways to overcome that problem, like sanding the lens, coating it with glue, all sorts........
As long as you do not cut through to the anode and cathode, you can abuse the lens as much as you want; cutting, sanding, grinding, etc .....
Just experiment......![]()
Of course.... That's a good tip. I mainly used them for fading effects, never as a stabilisator.might want to throw a 10 mf capacitor in there with a diode after it to keep the light steady without pulses.
i recommend using shrink tube over all exposed wiring, or just plain rubber or ceramic to cover the bare wires where ever they show up.
There is no going back for repair ......
