Sonar
Well spotted Jim, "squinty" strikes again. Finally made the fairing and attached after a lot of fiddling the bow idesigned goes to too much of a point for easy fixing so fast setting glue would be a bit difficult so it was a case of setting the front flare then working the rest of the fairing into place using the sonar piece to mould the joint. Needs a bit of glue and a sanding then a couple of coats of acrylic should fix it well enough. Hopefully I now have design for the propellors which should work.
@Elb
The platforms actually should droop it's the line of switch boxes that is the trouble they are all over the place and that is the view I wanted to get right looking down the deck to the bow. At the moment I am not into rebuilding anything. I have a block on perfection.
I have to go through all the photographs now to find where the aerials are.
regards
@Elb
regards
