Cyberpunk Garage Papercraft Stand For Diecast Cars In 1/64 Scale
mauther
317
238
Sao Paulo-Brazil
Here is another small stand/diorama in the same style as other models already published here on the blog, but this time with an atmosphere fully inspired by the cyberpunk universe, filled with neon lights, glowing signs, exposed pipes, worn concrete and that typical look of futuristic megacities seen in science fiction movies and videogames.
Just like the Hillbilly Garage Stand and other similar models already shown here on Papermau, this diorama was created especially for 1/64 scale miniatures, making it perfect for Hot Wheels, Matchbox and other diecast cars of the same size. The dimensions and assembly structure remain exactly the same as the previous models, changing only the textures and the entire visual identity.
The model fits on a single printed sheet and includes two complete stands on the same page, allowing you to build two separate dioramas or even combine both using the relief technique. The textures include wet concrete floors reflecting colorful lights, aged metallic doors, futuristic signs, illuminated panels, glowing windows and several small industrial details spread across the walls.
The assembly is simple and accessible even for beginners in the hobby and, for best results, I recommend printing on paper between 160 g/m² and 200 g/m². Those who wish can also add small LEDs to make the neon effect even more interesting.
A small tip for those who want to achieve that shiny, wet-looking effect seen in the photos: this can be done very easily by applying two or even three thin coats of regular white glue over the assembled parts. Simply use a medium-sized brush with soft or medium-soft bristles, spreading the glue as if you were painting the model. Once dry, the glue creates a subtle reflective finish on the floors and walls, while also helping to reinforce and “seal” the papercraft, protecting the colors against fading over time.
This small diorama is ideal for photographing miniatures, creating futuristic scenes, composing dystopian urban layouts or simply decorating your shelf with a compact scenario full of cyberpunk personality.
Link:
Cyberpunk Garage Papercraft Stand For Hot Wheels And Diecast Cars In 1/64 Scale
