Climax Dress up kit?
Welcome back Mrgooch!!
It's been a while since you were last here.
The cab is attached by two phillips head screws that thread up into tabs at the bottom of each side of the cab casting.
the cab lifts vertically off the boiler, so be careful of the piping that goes through the front of the cab.
You will also have to rotate the "reverse gear lever" forward, to get the Johnson bar link out of the cab wall, and the knots in the bell rope have been glued, so you will have to cut one end or the other (I cut the cab end knot off).
Pete
This is the On30 climax Shamus built:
