N Nick8564 New Member Sep 3, 2004 141 0 40 Dec 8, 2005 #1 Best way to transition from code 100 to code 83 I want to know the best way to transition from code 100 to code 83. Thanks
H Hammerli New Member Nov 19, 2005 37 0 Dec 8, 2005 #2 I don't know if it is the best way, but an easy way: http://www.walthers.com/exec/productinfo/948-897
DanRaitz New Member May 30, 2002 300 0 Maricopa, AZ, USA Dec 9, 2005 #3 Atlas makes transition rail joiners for C100 to C83. They are Atlas #551.
brakie New Member Nov 8, 2001 2,827 0 78 Bucyrus,Ohio Visit site Dec 9, 2005 #4 A thin cardboard shim will work as well.Make it as wide as the track and the ballast will cover it.
N Nick8564 New Member Sep 3, 2004 141 0 40 Dec 9, 2005 #5 If using the atlas rail joiners will i have to file the code 100 track to meet the code 83, and how does that cardboard shim work?
G green_elite_cab Keep It Moving! Apr 4, 2005 1,876 0 36 Hainesport NJ Dec 9, 2005 #6 you won't have to file any track. the transition joiner is alittle higer on one side ( to mate with the code 83), and a little lower on the other side. the Ties are actualy taller on code 83, or so i've heard. they should match up
