- Apr 5, 2013
- 14,215
- 10,837
Z the reason the liquid cement clouds the clear plastic is all in the chemical make up of clear polystyrene verses regular opaque plastic... while the cement liquefies the opaque plastic, and to a lesser extent the clear plastic, the vapors from the liquid cement out-gas and affect the clear plastic.
I've had the same problem with regular glue also. I found that if you use very little on both sides, then connect parts, just as parts softens, before it dries, then the haze does not occur. This is something that did not happen when I was a kid. I think the glues have changed, maybe now made in a less expensive formula. I also only glue a "dot", and fit the cockpit first, so less becomes more.
