Athearn Handrails
diburning
90
I have an Athearn blue box Conrail GP40-2 that needs handrails and I want plastic ones instead of metal ones.
Will the Atlas ones fit? If not, will I have to buy a set from Athearn and then repaint them? (Athearn doesn't make the plastic ones in Conrail blue
Not likely. If you can get replacement handrails from Horizon (Athearn) you will likely have to repaint them. If you do, I suggest you get a paint made for lexan RC car bodies, as it's more flexible, and won't flake off the way most model paints will. Faskolor by Parma comes in a wide range of colours - something should be close to CR blue.
