Scott, Tetters, thank you guys
Lance, thank you for your encouraging comments. Yes, the building in the foreground is Sentry Industries. They are getting all those tank cars (and I like tank cars), that’s why I want to model it. When I first thought of the extension, I wanted to build Sentry and the warehouse left of Sentry (the one with the curved backside), but to have both structures would have completely blocked the view to the tracks and the background buildings. So I decided to do without the other warehouse. I want to build the front of Sentry true to scale (as far as I can get the dimensions right), but move it to the left so that it will have the curved back. To get the dimensions, I measured the door of the office I found in one of your pictures and then calculated the other dimensions compared to the height of the door. The mock-up shows that I’ll have to make the loading doors a bit wider and and add a little to the height of the building. I think if I make the height 2 1/2", it should look right.
Isn’t it sweet? Josh, I knew you’d like it. I only got it a few days ago. It is from Trucks n Stuff.
Josh, those pink colored warehouses are the same you can already see in the first pictures of my thread. I only painted them a few days ago, but they are still far from being finished. I am making these buildings out of sheet styrene and if it helps you, I will do a little tutorial when I build the next one.
.Lance, thank you for your encouraging comments. Yes, the building in the foreground is Sentry Industries. They are getting all those tank cars (and I like tank cars), that’s why I want to model it. When I first thought of the extension, I wanted to build Sentry and the warehouse left of Sentry (the one with the curved backside), but to have both structures would have completely blocked the view to the tracks and the background buildings. So I decided to do without the other warehouse. I want to build the front of Sentry true to scale (as far as I can get the dimensions right), but move it to the left so that it will have the curved back. To get the dimensions, I measured the door of the office I found in one of your pictures and then calculated the other dimensions compared to the height of the door. The mock-up shows that I’ll have to make the loading doors a bit wider and and add a little to the height of the building. I think if I make the height 2 1/2", it should look right.
BTW, I LOVE that rig you got parked in front of that building :mrgreen:
