Morning. Reclinerized too long. Woke up about 30 minutes ago. wall1 Off to bed. 60103, you must have gone South to find a beach with no snow in Canada. Where was the picture taken? Good night all.
Good morning !
All the shootings all over the country !! We had ours too, yesterday guy killed 3 people in family then called 911. SWAT came, 1 officer killed, another wound. Burned the guy out, he died as well.
Glad the carpet issues worked out, that can be a real pain!!
FINALLY, got my power wiring done! Next will be the switches. Below a couple of pictures below the layout.
The white background behind the terminal strips, is a wire list identify where the wires go. If you look close right in the center at the bottom of the middle AIU, is a wire hanging. That wire comes from behind the panel and goes to the TMCC Command Control. I unplugged it from the TIU on the right side, to accomodate access. Well you guessed it, when I finished I forgot to plug that wire back in. I had Drag Races going on when I powered up the layout. The good news is, that was the ONLY wiring issue. EVERYTHING worked great the first time, Unbelievable.
The next picture looks like a mess, but I have my control panel, and all my transformers mounted in a printer cart. (Which is really working well, with the pullout drawers, and can pull the whole thing out from under the layout. These cables are umbilical cables to accomodate movement. The reason there are so many is that also included on the cart is a VCR, Xbox, Xfmrs for the elevated G scale. The yellow is a power cable that goes to 2 emergency shut off switches, one at each end of the layout.
Hope we ALL have a safe, and quiet weekend. Today should be a great day, suppose to get up to 75 today!!
Later, Don
