As you can tell from this pic, my layout once had a passing siding that was created via two curved switches -- one in the lower left and one in the lower right.
Well, I've had derailments off and on at the lower-right curve. This curve used to be a Hornby turnout but I learned that Hornby's curved switches aren't the greatest quality so I replaced it with a Peco switch -- supposedly the best.
Well the problems persisted off & on even with the Peco switch. :cry: These problems worsened over the past few days as three of my main locos derailed at this location. Two of these locos are very new, so it's probably the track that's at fault.
Last night, I made one last ditch effort to solve this. After an hour so or, I gave up and removed the curve altogether, but even this took me 2-3 hours to get the curved shapes right and solve derailments! I will simply use this siding only with the one turnout now.
I doubt that this Peco switch is causing the problem. I suspect that it's due to how I've laid out & positioned my track. It could even be caused by the location on the board where the turnout was placed as it's become rather uneven now after so much adjustment to the road bed and ballast.
Just wondering if anyone else has run into similar problems or has suggestions. FYI, I'm not mechanically minded at all so I really struggle with things like this.
I'm sure many other folks could pinpoint the problem right away!
Thanks,
Rob
Thanks,
Rob
