'Skid-Fizz' or to be precise Sd-Kfz 250/3 GREIF
Chuffy70
1,217
2,574
Norwich UK
WW2 modelling is a subject I left behind in the 80's
Aircraft, tanks and small soldiers were all constructed, painted and played with, yes played with. Usually recreating some kind of battle in my neighbours loft on his train set layout.
I knew enough about various vehicles, planes etc to tell them apart, but never really anything in-depth to say what variant or Mk they were, basically every Sherman, Tiger, Spitfire or Paratrooper looked the same...within reason.
Over the last few years watching @snake7 build his wonderful renditions of armour of old, I've been tempted to dip my toe back into the World War 2 era.
By chance a guy at my local model club handed me a USB stick and said have a look at these... Upon opening the device, I was overwhelmed with a 150+ paper models, 90% of which were WW2 subjects his friend had scanned in, before making them.
Looking through the files I noticed a vehicle which hit a nostalgia vibe.
Matchbox, in the mid-seventies, produced these wonderful 1/76th scale vehicles, moulded in several colours which helped younger model makers build out of the box something that resembled the box art (painting would be needed for other variants) they also came with a tiny baseplate/diorama for you to display your finished model on. I built a few, some never finished, and surprisingly a few are still in my possession... still unbuilt!
Revell acquired the moulds of some, if not all of Matchbox's back catalogue and a few of these kits can still be bought today.
This particular one, my brother found going through some of my old boxes of stuff! Could be built as an Afrika Corps version too.
A bit dusty, but still in one piece, although the German trooper departing over the side of the vehicle, seems to have gone into battle.
The second part of the nostalgia was noticing the particular file I had chosen had 'GREIF' on the side, of which had sparked another memory of looking through my brothers old Airfix catalogues and the wonderful artwork which adorned the box tops.
Thus, its the model I intend to have a go at... Released around 2004 by GPM, the kit consists of 8 sheets and a squillion parts!
Having never built one of their models before, I looked over the bits and picked what I thought looked half-way easy to make first.
Picking some Jerry cans and weaponry as a first strike.
The cans can be assembled simply, or by going the extra mile, cut-outs and backing plates are provided to give you an extra bit of depth.
Viewing some pictures of the real thing came up with with a few discrepancies in the handles and also the filler cap is not central, but off-set.
Unable to verify the correctness of the parts, I just pushed on. However at the scale, I thought about having a go at adding a few details around the filling cap.
Top & bottom shot of the first few added parts - A back thumb plate? also a bar from some brass wire across the top.
Some kind of catch plate (middle was cut out to aid the fit)
After a weeks work, I have six Jerry cans!
Cans of Jerry
I also added a 0.5mm strip of paper ahead of the brass wire to give it a small bit of extra detail, which can be seen on the photo of the real thing.
I probably won't go into as much detail on this build other than showing parts vs built, unless I add something extra.
Anyway, hope you enjoyed my re-entry to the world of WW2, and I'll update as and when.
THANKS FOR WATCHING...
Nice start looking forward to see your next update.
Thank you, will probably be something small at the weekend
Those Jerry cans look FANTASTIC! You are off to a GREAT START with this project. Iam looking forward to seeing how it turns out.
Cheers, I'm pleasantly surprised with them myself, but took far too long to make, I just hope the rest of the model looks as good!
Those "Gerry Cans" are great! :)
My second post for the Skid-Fizz... (childhood name I gave this vehicle)
Most of this week was research, both on the real thing and also on the model.
The instructions, detailed as they are, leave a lot down to the builder to figure out 'what goes where' and there's really a steep learning curve here, especially if you have not built a model from the publisher before.
Tiny sub-assemblies were picked from the illustrations.
Front tow hooks I believe, and some tools...
With large scale of this kit, some of the printed detail needed to be brought out.
I bought some moulds last year for another project which included nuts, bolts, rivets etc, so I rolled up some Milliput putty and produced some 'bits'
Paint test
Parts for seats and floor pan - the side rails took some head scratching, as the folds made no sense whatsoever! I just made them up in the end.
Seat backs had some added detail, as I noticed in some pictures, the seatbacks were tethered to the frames by straps.
I'll paint these a leather colour later. they will probably be unseen, but we''ll know.
Parts for the main drive shafts and clutches - for such a large sub assembly the instructions were far from helpful, It took a couple of nights to visualise this, even plastic model parts from plastic kits and the real thing looked different! I'm even sure there's two discs missing???
Once again, I made this up to something which vaguely looks like it should be there.
Inner floor and sides.
Lefthand upper-side seatback and stowage bin, which has no placement showing on the instructions!
lower bench and seat-cushion
A weeks work lumped into the interior... Sorry, but the picture for the gearbox (centre) was lost, although it was an easy build.
Nothing painted yet and getting my head around where everything goes.
Thanks for watching...
This model is going to teach you a lot. Your foundation is great. ;)
I'm hopping on the train with others. This is going to be a great build!
It's my honor that you mentioned me as some inspiration:cool:
You are doing a great job adding all this details to the assembly!
I have this model in my stash, so will build it in the future and definitely will use your build as reference.
Now I'm more interested how did you printed sheets of parts? Which paper, printer? I understand this is not the original book?
Welcome on board the crazy train!
You definitely make the GPM kits looks easy on your builds and its 'my' honour to mention 'you'
Answers to your questions are A3 onto 180 gsm & printed at my local copy shop. Yes, not the original, but scans from my friend
I hope the build turns out as good as one of yours...
