In this thread I will attempt to build one of motor sports arguably most striking cars.
Hopefully it will be a gift to one of my local model groups members, as this ranks highly as one of his favourite cars.
Sometime ago @zathros put this into the resource section, along with the interior, so this build will feature that.
A bit out of my comfort zone as to knowledge of this subject, but we will give it a go...
Parts selected for the interior.
Some selected bits to start with.
Cut and folded.
Steering wheel and boss - cotton bud shaft for possible replacement of paper one
The rolled boss was a bit crude, so a replacement will be cut from the bud shaft.
Shaft replacement cut and steering wheel folded to what looks correct. Handbrake was a bit thin, so extra layers were added to bulk the part out.
Not even sure you'll see the pedals, but I have cut these out to add anyway - you & I will know they are there
Front of steering wheel.
Floor and sides of the tub were also bulked up with extra layers.
Most of the interior is now prepped for construction.
Seat platform and seat locaters added. Also side parts.
Here we have a first fault, the tunnel which the gear selector runs though is too long...
Instead of cutting off the end, I opened up the square on the bulkhead and passed it through.
If it gets in the way of anything later, then some judicial extraction will be needed.
Curved panel, presumably the wheel arch ingress were added along with the handbrake box.
Reverse of previous.
So far this has come together without much of a problem, albeit the instructions, or lack of, just a call out sheet of parts are very basic and part numbers duplicated in a very frustrating way.
THANKS FOR WATCHING... more coming soon
Cut and folded.
