2001 Orion by Pilsworth (quick build)
Chuffy70
Well-Known Member
Jun 5, 2022
1,204
2,546
95
Norwich UK
In a effort to help out fellow builder @seraphim - I shall be building the Shuttle craft, or Orion Clipper fro the film 2001 A Space Odyssey.
A plastic model of this ship sat in my brothers display case for many years, before I actually saw it at the cinema, gracefully spinning into action so to speak.
I have planned to build the Orion for my brother for Christmas, so in a strange twist and a call for assistance from @seraphim to help. I thought I'd bang the Pilsworth model out, before tackling the UHU at a later date.
Its a bit of a basic looking model and the instructions are not very clear, but we'll have a stab at it and see what the build brings. I just hope this of some help.
PLEASE NOTE THIS IS MAINLY AN INSTRUCTIONAL GUIDE TO HELP A FELLOW MEMBER - QUALITY AND CARE WILL NOT BE ADRESSED.
First sheet covers the main front fuselage
First set of parts have been cut out and rudimentarily formed over a plastic pipe
Cockpit widows have been creased on all available angles including the widow supports - tiny top two tabs have been attached to the upper hull
Rear of front cockpit window, arrows showing glued tabs, sorry poor pic!
Next section of the nose - forward of the cockpit windows with the black anti-glare panel was added next, Tabs glued either side of the cockpit windows, then the windows glued to the section
The front nose section needs to be creased across the line indicated
As I had not quite formed a tight enough curve on my hull, I glued a tab one at a time on the port, then the starboard side first, then the next tab up.
Red arrows are the first glued tabs, then the blue arrowed tabs were bent backwards and glued up.
Front half of the ship should look something like this
With all hull sections stuck together froward of 'PAN AMER' it was onto the 'ICAN' and head backwards...
There's nothing really to note on construction of the rear hull, as tabs very much guide you through alignment.
CIRCLED EXTREME REAR OF HULL LEFT OFF UNTIL LATER
Blue circled, same as red above
THIS COMPLETES UPPER HULL SECTIONS - NEXT INSLALLMENT INTERNAL FORMERS AND WING CONNECTORS (probably?)
Any questions please do ask away!
Great work! You are a fast builder. It would be great to see some side-by-side pictures of the finished models later. :)
Reactions: Chuffy70
You are off to a great start on this project! Thank you for taking the time to conduct a detailed and thorough build thread of this template. I am looking forward to seeing how it turns out.
Reactions: Chuffy70
Yes that would be a good idea, best I keep hold of this instead of giving it away!
Well so far, so good... and thank you
Nice work and indeed very fast.
...it's all in the reflexes
i think if formula 1 racing ever start kit building you will definitely win lol awesome build so far and thankyou for the help :toast:
  • Haha
Reactions: Chuffy70
Righty'O - second part of the Orion build. @seraphim
Bulk heads are requested to be put onto the corresponding joins.
When they were cut from the sheet, I made notes as to what one went where.
The rear bulk head has to be fitted correctly so that the hull conforms to the shape.
As the bulkhead was glued the rea of the ship began to take shape.
Slightly out of sequence here, bu the rest of the bulkheads went in with no problem.
Backplate which fits over the rear bulkhead was acquired next.
A quick dry fit and it was fitted a tab at a time.
NOTE - I LEFT THIS PART TO PULL THE REST OF THE HULL TOGETHER & NOT GLUED TO THE BULHEAD UNDERNEATH.
Plate fitted.
This rear plate formed up the back of the ship quite nicely.
Upper wings were requested next.
ALL LINES TO BE CREASED - APART FROM THE INNER PART WHICH MEETS THE HULL - THESE ARE DENOTED WITH A '
RED T'
However further into the build these should be creased downwards.
The rear edge of the wing needs to be stepped down.
Trying to show the step with the wingtip bent upwards.
Close up of the wing tip as to what needs to be cut out.
These parts are the trailing edge.
NOTE EVERY LINE HERE NEEDS TO BE CREASED
Outer most leading edge to be formed like this
...and the other end
The leading edge fitted to the top starboard side wing.
The other part of the front leading edge needs to be creased and bent in the same way,
After all that, the front parts of the upper wings should look something like this.
The rear flaps on the upper wing are not yet attached, the parts circled are yet to be identified, but I'm sure they have something to do with them, so I have cut out the underside belly to better understand the fit.
MORE ORION FUN TOMORROW
Plate fitted.
RED T'
View attachment 216356View attachment 216357
looking at these bits (last 2 parts for rear of fuselage) would they go along the fuselage at the rear of the wings (where the flaps meet the fuselage?) AGF000041.jpg
although the build is a mainly simple one this is one of those 'hmmmmm......?' parts not detailed lol. Your build is coming along great :BRAVO:
looking at these bits (last 2 parts for rear of fuselage) would they go along the fuselage at the rear of the wings (where the flaps meet the fuselage?) View attachment 216362
Yes. I'm quite sure they do, as to their orientation and fit, that's the £100 question!
The model came out superb. If you used strips instead of tabs, you would have even better hull fitment/fuselage, and since the strips can be added to the bulkheads, you could have made each section, and had a straight fuselage before you mounted it to the wings. However, the model looks superb!! :)
Thank you @zathros - kind words & great input, your suggested upgrades I utilise on most of my favourite and more intricate builds, but this model is being made 'as per the instructions' and purely as a guide.
I'm sorry to say this, but this version is not really worth the effort to enhance by your recommendations, when there this a far superior, although harder version to build.
I guess you are referring to the UHU Version. Uhu uses a lot of graphic lines for apparent detail, these also give you a guide for further enhancement. It's on my bucket list too, as is most of his 2001 Space series. ;)
Yes Guv, I mentioned it at the start of the build... looks 100% better
all of UHUs work is amazing, and very detailed. My question would be whether to build it with full interior or not? Its a shame that this version is quite lacking in detail, but makes for a reasonable quick build i guess?
Reactions: Chuffy70 and mijob
A couple of years ago I made the Moon Bus, it had a full interior, although most of its hidden, most of the internals are structure related, so I would seem plausible you would have make most of it anyway.
As to how much you add is up to you...
My Moon Bus interior
More Orion gubbins...
Getting nowhere with the instructions and dry fitting becoming too complex to fathom, I attached the bottom hull to the nose cone tab.
This let me raise and lower the belly to see where everything needed to go.
A main wing spar runs through the wings, folded into a square tube.
Main belly dry fit.
Rear part of main top wing added - once again, note the step in the wing.
Spar constructed and fuselage side wing guides. Note square hole notched out.
Although the side guides matched the notches, I feel these have been labelled wrongly as left should be right & right should be left!
Once installed the black indicator should be at the front and the rear should have the sloping end trailing into the tail.
The belly is too long on the dry fit, but this is correct and will sit correctly once construction continues.
Note the angle which caters for the seemingly over long belly.
Installation of the spar, unfortunately it fouled the step in the wings, so I left it out.
Hinged access
The blue arrows show these tabs to be folded inwards and will sit on the belly and the red tabs with the red 'T' on them should be bent downwards and not kept flat as per the inept instructions state.
Cursing and swearing about the flaps which the dry fit showed up, but slowly getting there!
The odd parts which were finally identified as fitting here.
All flaps here should face down
With all mating edges and tabs in their correct orientation, a liberal amount of glue was plastered inside and we nearly have a starship!
WILL LEAVE IT HERE TODAY AND HOPEFULLY FINISH UP TOMORROW...
Getting nowhere with the instructions and dry fitting becoming to complex to fathom, I attached the bottom hull to the nose cone tab.
Main belly dry fit.
View attachment 216368View attachment 216369View attachment 216370
Hinged access
im glad to see it wasnt just me having some, er, 'clarification' issues with the instructions lol, that said, youre doing a fine job, looks great :toast:
Reactions: Chuffy70
