- Apr 5, 2013
- 13,908
- 10,293
- 228
That you drilled out every hole for the rivets blows my mind!
That you drilled out every hole for the rivets blows my mind!![]()
Just and hour and a half, eh? Start planning the display case.Twice, the first ones that I rejected and then threw away, I also drilled. And so nothing at all, about an hour and a half for all the frames. It took more time to position the frames on paper and glue the tape inside them.
One and a half hours for each set of framesJust and hour and a half, eh? Start planning the display case.![]()
The display case has not yet been developed. I am thinking of making 2 options, one for the house in an assembled state under a transparent cap, the second for exhibitions so that it is divided into all parts and they stand separately. With the first case, everything is very simple, but with the second one I still think how best to do it.Start planning the display case.![]()
I agree. The 2nd method woul be most informative, and interesting display to look at.The display case has not yet been developed. I am thinking of making 2 options, one for the house in an assembled state under a transparent cap, the second for exhibitions so that it is divided into all parts and they stand separately. With the first case, everything is very simple, but with the second one I still think how best to do it.
Make it lifesize and tell your wife that this will be your new house then.And if it will also be in two versions, then I'm afraid that my wife will kick me out of the house with my models.
@Revell-Fan Can I ask you to unfold this part? I will try to do working mechanism, if it possible in this size.Having seen the video I tinkered a bit around and came up with this:
View attachment 192649View attachment 192650View attachment 192651View attachment 192652View attachment 192653View attachment 192654View attachment 192655
It is by any means not perfect because I don't have any measurements (and I doubt you could use it on a real Apollo capsule) but if you like I could turn it into a pattern you could use for your super-detailing.
I'd love to but I don't find the file any more. It may take some time till I have checked my hard drives.@Revell-Fan Can I ask you to unfold this part? I will try to do working mechanism, if it possible in this size.
