Every part of this build qualifies as a complete model by itself. This is astonishing work.Those seats are a complete model by themselves!
Now I use local service. In the future I plan to buy a laser cuter, maximum for 40x60 cm working area.Do you have a laser cutter or local service?
Your capsule is fantastic!
This is not aluminum foil, this wallpaper is a very thin plastic sheet with an aluminum coating and an adhesive layer, it is easier to work with and it does not scratch or shrink as foil.I worked with aluminium foil before. You have to be very careful or you'll end up with wrinkles or scratches. Great work so far!![]()
