- Apr 5, 2013
- 13,959
- 10,377
- 228
Thanks Mate, everything is moving pretty smoothly now.Looking good! keep up the good work!
Thank you for the kind words. Glad I read through to the end though I was just thinking where the shovel was.When I worked at Sikorsky Aircraft, whenever a critical parts was made, that part was put in an offsite facility, deep in the ground somewhere, to act as a reference copy. This model looks to be of that quality, though I do not think it should be buried!![]()
I get that aspect, I am more interested in how they line up with the outside of the rocket. For example, part 10 goes in section A, B. or B,C, etc. If I can figure out one then the rest will fall into place.The inside parts fit against the exterior parts so where the outside joins so does the inner parts. Hope that helps
Thank you. That was exactly what I needed.As u said it, part 10 goes in section A and round u go!
the final result which does look really good.
