Hello to all,
This time there isn’t much to explain. Tedious works where they are. First the engraving and soon the sidebands of the tires. And following, all the pieces that compose them. Altogether around 80 pieces. I assure to you that it is a heavy work, but soon has its rewards, because I believe that these tires have all the numbers to look very well.
In Pictures 91 and 92 you can see different phases to cut the inner curved part of the engraving.
91.
92.
In Pictures 93 and 94 a strip of engraving in process and finished and in the Picture 95 the five strips of the tires finished.
93.
94.
95.
The same for the sidebands. Picture 96 just shows a cut band to you. In this case I used the scissors. Very small ones with the end doubled towards a side. They go very well, but it is necessary to go little by little, taken care to perfectly follow the printed line without going out. One leaves the sight and the patience in this task. In Picture 97 all the bands already cut.
96.
97.
And tachan, tachan!, in Picture 98 all the pieces that compose the tires already cut.
98.
Soon I will show you the progress on these.
Greetings and until soon companions.
91.
93.
96.
98.
. Hasta luego compañero!
