Continuing with the quarter galleries.... :lol:
I added the roof piece, finished up the lower fairing and put some trim around the windows on the starboard gallery.
The roof was a cut, fit, trim, fit, trim, some more trimming and final fitting type of deal since there is no way I could figure out the correct shape any other way.  :roll:  After a bit of cussing and fitting, it finally took the right shape, so I glued it in place.  I found that coating the paper with glue helped to not only get the paper to take some strange curves but when dried was nicely rigid.  I then painted it flat black to represent the tarred look she has in real life.
Next, I finished up the lower fairing, again using a bit of glue to try and make a smooth transition between the pieces that make up this part of the gallery, and then gave it a coat of white glue.  When that dried, I again painted it flat black.  I use acrylics, which I find very easy to apply, without the odors of petroleum based enamels; makes it easy to clean between colors too.
Then the trim was added.  I used thin strips of paper, sliced fine with an exacto blade using my small steel ruler.  The trick here was to glue it without pulling the strip into pieces as it was adjusted into the proper location.   I tried to get it so it was level with the transom trim, like in the real thing, which took a bit of maneuvering with my needle point tool. The trim of the galleries wrap around and flow into the transom trim. Easy does it is the word for this work, because if the now glued paper is pushed too hard it will quickly tear.  I did manage a fair blending of the trim into the transom trim, after a bit of prodding.  Whew!
I also added the little trim piece at the top edge of the roof, that short white piece.  It went on fairly easily, lucky for me! :lol:   It coated it with white glue, which seems to also smooth the surface so it looks a bit better than raw paper.
I then cut some ridiculously small squares for the trim at the top of the window pedestals.  This is when I learned that the card stock I am using (which is about 67#) is actually laminated sheets...and the laminates will break down if the itsy bitsy piece is pushed too far. :shock:   I had to redo one or two of these trim pieces because the upper part separated from the lower layer when the glue dried too fast during positioning.
Finally, the gallery was almost done!
   I did a bit of touchup, tried to paint the spot where the gallery meets the gun stripe to make a crisp separation when I realized my hands tend to shake a bit.  :?  Luckily the brush I was using was fine enough to allow me to complete the job without too much of a ragged line, despite the slight shake that could have translated into disaster...yes, I held my breath as I painted to steady things up, and it came out okay in the end.  I also took a chance and used a very fine brush to put a bit of white paint on the trim pieces, and by this time my hands had steadied up so I didn't mess it up entirely. :lol:
Jeez, between the bad eyes, shakey hands and delaminating paper, I think I'm going to have to rethink doing stuff this small in the future...nah, just kidding, but it was a little hairy.  I have to say this part was the toughest so far...ah, but the rigging is still ahead! :lol:
Meanwhile, back at the ranch...flush with the way the starboard side came out, I started work on the port side gallery.  Sure, you'd think after doing the starboard side the port side would go easier.  Well, it did in some ways, until I realized I installed the window pieces a tad too high for the trims to match up with the transom trim. :shock:   Yep, had to remove the window pieces and start over.  How the pieces didn't disintergrate in the process, well, I guess I was lucky, they stayed together fairly well.  When I finally got the pieces at the right level, it was some of the same, fit the lower support below the windows, add the fitted, trimmed, fitted and trimmed roof, then the trim pieces.  I again added a bit of white paint to the trim strips.  While things were drying I finally got to color the lower rudder and the lower part of the stem to match the copper plating...every time I looked at the photos I'd slap myself on the forehead because I kept forgetting this little detail. :roll:
Ta dah!  The galleries were completed!
I also had time to add the waterways to the inner bulwarks.  They are a pretty noticeable feature if you go to see the real Constitution, so I had to add them.  I cut out long, narrow strips of paper and painted them the color of the bulwarks.  I then glued them to the lower bulwarks and deck at an angle.  They are about a 45 degree angle from the bulwarks, which was a tad difficult to achieve beause the paper wanted to either flatten out onto the deck or to straighten out along the bulwark.  After a bit of prodding with my fine tweezers, and re-adjusting the twist of the strip, and some more prodding, they were finally in.
I also added the strip on the inner transom that represents the original cap rail, much like the strips along the bulwarks.  At the transom,however, there is a small knee piece at each corner of the transom, so I had to again trim some scrap and fit them in place.  I am learning a bit how to brush some glue on the fitted pieces to help fair up the edges so they flow smoothly into the existing piece.  Well, you can't really see it too well in the photos, but the glue made it look better than without it. :lol:
Finally, in a bit of madness, I decided to add the small steps on each side of the inner transom.  These were made up of two pieces of small strips which where then pre-painted black, dried, and then glued into place.  At this small size I have to be careful to make sure I don't apply the paint to heavily to the pieces.  Because I have to use a clap to hold the piece for painting when the part just painted is dried, I have flip the piece to paint the other, unpainted part.  If the paint if applied too thick (which isn't really a lot of paint at this size, even a smidgen too much paint creates a problem) then a slight uneveness appears where the freshly painted part meets the just dried part...is that clear??? :?   I found if I brush this interface a bit, it will smooth out nicely.  Just something I thought I would mention. :lol:
Well, after the paint dried thoroughly (and making sure all exposed edges are painted), I then put the steps in place.  The upper step is placed slightly inboard of the lower step, as you might see in the photo, not even with each other.  That's the way it should be, actually, I suppose to help someone climbing the steps to clear the knees of the rails.
Well, that's it so far!  I plan on working on a few more exterior hull details next time, like adding the bumpkins, doing something with those hideous bright blue lights just above the copper plating line, and working on the gun deck lids.  I'm not sure if I will add those gun deck barrels at this point or wait until just before the rigging starts to avoid knocking them off while working, but they shouldn't be too much of a problem...and I would love to just finish up the exterior hull before getting into the spar deck furniture and carronades, etc.  Decisions, decisions.... :lol:
I'm including a few full hull length shots this time just to sort of show you where I am overall.  Slowly but surely the hull takes shape....
Cheers!
Jim
