You folks are way too kind, thanks!
I figured I'd post the process I am following to rig the carronades including how I make the eyebolts used in making up the tackles.
The wire I am using is Nichron wire of 34 guage...not sure what that translates to in diameter but it's the smallest stuff I have come across. It's apparently the type of wire used for toasters, etc., but it's wonderfully flexible and easy to work into an eyebolt.
The tools I use are a mandral fixed to a handle, the mandral having a diameter of 0.023" (at least that's what I'm told), a pair of pliers, scissors and a small clip used to hold the eyebolt at various stages.
The first step is to wrap a length of wire around the mandral twice, this creates the eye of the eye bolt. I hold one end along the barrel of the mandral handle, and wrap the wire counter-clockwise around the shaft. I found going the other direction makes it difficult to later start the twists, for some reason. The next step is to trim the ends a bit and twist the two ends together around four times just to start things off...it's here that if I wrapped the eye clock-wise it seemed to take about six to eight twists to get it started...again, I have no clue why that would be. :? The next step is to use the pliers to continue to twist the ends until I get a nice, tight twist of around 2 - 3 mm long. This takes about eight to ten half twists with the pliers (since my wrist does not have a spindle joint I can only twist the wire a half twist before having to re-set the plier hold on the wire...others more talented can probably do better. :lol: ). The twisted stem is now trimmed up to about 1.5 mm. I found using the little copper clip is the best way to handle this small eye bolt, so it was then used to remove the bolt from the mandral...and there you have it! As it now stands I find I can whip out an eyebolt one every two minutes or so, give to take a bit if I have trouble getting the pliers to grip the stem for twisting.
Pretty easy thing, I know, but I figured I would share the obvious with everyone anyway. Next, I will show how these eyebolts are used to rig the tackles.
Cheers!
Jim
   Next, I will show how these eyebolts are used to rig the tackles.Cheers!
Jim
	 ; the not so good news is it took be all of yesterday afternoon to figure out the tackle jig and to make up the sets of tackles for the two carronades you see installed, as well as to install them both.
 ; the not so good news is it took be all of yesterday afternoon to figure out the tackle jig and to make up the sets of tackles for the two carronades you see installed, as well as to install them both.  Better news is that now that the jig is figured out making the tackles should go faster.
   Better news is that now that the jig is figured out making the tackles should go faster.  ops:   I was hoping to use those little copper clips, but the pressure on the jaws are not enough to hold the ends of the wire secure enough to twist, they just pop right out.  I will have to try it out, however, and see how they work...anyting that speeds the process along is a great idea!  Thanks!
