Uhu02 interstellar Endurance
#3 gets my vote also. You can scale it up a bit bigger and seal the model in there with a Lexan bent front, and Lexan sides. Dust proofing it. It is quite nice. ;)
Reactions: Sky Seeker
I have to say that I like #3 the best! I think that it is a great way to showcase the model. I may do the same thing with a few of my models in the future.
I was wondering if you would be willing to share the base idea of #3 in the RESOURCE SECTION in the Display Stands category: http://www.zealotmodels.com/resources/categories/display-stands.117/
I already did it when I uploaded the base for my Moon Liner, but, like that time, I'm usually doing specific model stands (see my Collier's Ferry Rocket), and this time some friend suggested to use Lexam for the curved wall paper and so also the base should be wooden. At the end not so much paper ...
Because i'm entering in a technology I don't master, I'm thinking to do the first version as backup solution in the worst case.
Here some step doing the Central Docking Hub.
The following pics depict the most challenging passage, where i think I earned my degree in cutting impossible details.
Here it's were I am, the last picture depicts simply a dry fit, next magnets, docking
connectors for the rangers ....
Best, Nando :)
You aren't kidding!! Flawless building!! :)
Reactions: Nando
The connectors for the Rangers
Next the Lander
The central hub and the lander seem to me very heavy, and I think that I'm putting only one magnet and not two as suggests the sensei. The single neodymium magnet is strong enough ( a strength of 1.9 kg )
Next the second lander.
Now the Rangers
Best, Nando
Nando, you work so meticulously and your models look so clean. A pleasure to follow your build threads! :)
Reactions: Nando
The rangers have less parts but an intricate shape, and it was tricky keep symmetry and avoid the twisting.
The angle is wrong, but after some adjustment it's all right now.
Finally all the components of the central hub can go together, and they form a impressive ensemble, so strictly packed that i think that the docking maneuver was very hard.
Now all the components of the model are ready for the final assembly and the view is already impressive, at least for me: i can admire the amount of work done so far.
Next the final assembly o_O
Best, Nando :)
Very very nice indeed!! This will look great when all together, it looks great now. ;)
Reactions: Nando
View attachment 167333 View attachment 167334 View attachment 167335 View attachment 167336
View attachment 167337 View attachment 167338
View attachment 167340 View attachment 167341
Best, Nando :)
Wow!!:surprise::surprise::surprise: What a clean build!:Drinks::Drinks: Looking forward to seeing it completed.:)
Thanks for sharing.
Sky Seeker
:tank:
Reactions: Nando and zathros
Looking really good!! I do have one suggestion, take one of the Rangers and attach with a Magnet, then you could still play with it!! :)
Reactions: Nando
The good news is that I completed the model by gluing the parts of the ring, minus the central hub, but ...
Houston, we've had a problem ...
It's a big problem, actually two.
The first concerns bonding. I wanted to try to use a plasticizer to protect the color, but this made gluing with the vinyl glue less solid, and now some parts tend to come off when I move the assembled model.
I will solve it by gluing the parts again with cyanoacrylic glue.
The second is the most serious: the model, placed vertically, visibly deforms either by leaning it, or by hanging it, even without the extra weight of the central hub with lander and ranger. At present it is no longer possible to intervene with internal or external reinforcements of any kind. I think the only solution is to intervene with the stand.
I thought that the support should not be too visible but robust enough to provide the stiffness that is missing to the model through a series of tips that distribute the support. Here an image of my idea.
Any hint?
Best, Nando :(
