Problem with cars uncoupling
joe lent
2
:confused: Hi,
I'm having touble with keeping my HO freight cars from uncoupling
around loose corners...any pointers??? I have older Tyco and newer Athearn
Freight cars. The couplers look the same on all the freight cars.
Also, I have a older Tyco (Mantua) steam engine that barely moves in forward motion and yet flys around the track in backward motion. Any tips on
maybe reversing the motor so it runs faster in forward motion??
You can e-mail me at jlent@att.net
Thanks,
Joe
Joe,
First, welcome to the gauge!
Uncoupling usually occurs when coupler heights vary, or the couplers bind in a curve. With the variety of rolling stock you have, it could be either, or both.
With the loco....you probably need to add thrust washers to either the motor, or the worm shaft in the gearbox. This keeps the worm from moving front to back when direction is changed.
Pete
Welcome toThe Gauge, joe :wave:
The key to your coupler problem is the mix of Tyco and Athearn cars. Because Tyco was built primarly for the toy market, the standards are much looser than Athearn's which are built for the scale modeler's market. As you grow in the hobby, one of the things you'll want to do is change over to another coupler. Kadees are very good and offer a wide variety of retro fit kits, even for Tycos.
As for the lokey, it too is a Tyco and made for the toy market. The motors generally weren't made to be worked on, using rivets instead of screws during assembly, making it difficult for a beginning modeler to maintain. If you're handy, they make a great first llocomotive to learn on.
I think your problem is the mix of Tyco and Athearn cars. Athearn cars will have body mounted couplers which will swing toward the outside of the turn in a corner, the Tyco car have talgo or truck mounted couplers that will track in the center of the track in a corner. If you cut the coupler boxes off of the trucks on the Tyco cars and body mount the couplers with a proper height adjustment, and make sure your wheels are in gauge, I think your problem will disappear. It might seem more logical to modify the Athearn cars to match the Tyco cars, but talgo mounted couplers are almost impossible to push backwards through a corner at any speed since the forces on the coupler when pushing the car around a corner will tend to push the wheels off the track.
