Peco double slip
coachsig
40
Sebring, FL
I recently "inherited" a Peco doubleslip ( n scale). Unfortunately, the paperwork was no where to be found. Any help on the correct procedure to hook up the 4 uninsulated wires coming from the bottom of the slip would be greatly appreciated.
Thanks in advance,
Coach Sig
Someone asked this on the Kalmbach forum recently.
2 wires go to the main tracks, one on each side, and a wire to each frog.
the frogs should be wired to contacts on the switch machine at the opposite end and these will be connected to the wires for the main tracks. You might have further contacts to connect the main tracks to the neighbouring blocks.
(I've never wired an N scale slip.)
There may be an explanation on the loystoys.com site.
Edit:
I just checked and the info is here .
