Nezard J10 test built
yaniv
64
ok i got a copy for making the test built of this intristing project by nezard
so here u can found the printing page
i use epson r200 to print this model
next stage (pic 2) is to cut all the inside parts
i start with the cocpit parts
for now the modle looks very nice also the colors
i found for now only smol problem
thar is no outlines in the parts and its littel hard t me for make a direct cut
baaaa
icant bilive it
my light in my work rook is burn and no light for tonight
i can make progres only tomarow :(
I just received the model as well, I'll begin construction soon, and begin documenting progress in this thread (might as well not start another). I'll probably only be providing images when I run into snags, and when the model is complete.
hi to all
i found a new light on my place so i back to progres
here i finsh 90% of the cocpit
sorry for the bed pic qulity my cam not that good
Very nice start there Yaniv :)
Looks great Nezard...
Really looking forward to this build...
yes the control panel is realy nice and deteling
i add 3 SUPER GLUE point on the 3 lcd green screen and its look screeny
Paragon you are most welcome to post suggestions here so I could improve the model accordingly.
BTW Nice work on the instrument panels Yaniv! (wondering if it's a bit TOO colourful for the real thing...)
Great pic there... Compared to Yaniv's pic he linked to and his build so far I'd say it was spot on for color and detail... very nice :)
Simple: tabs. Tabs for connecting the parts. Plus making the parts that need to be cut out white, instead of the same color as the nose. Also, on the bottom of the nose, the white confused me, I thought it was supposed to be cut out, but now that I look at it, I realize that it probably should not have been, because the intake has to attach there. Make those parts a different color too, and make the instructions a little more clear.
One more thing, there are no clear instructions as to how the inside of the intake is supposed to be assembled. I assume 25 goes inside 20, but I'm not sure.
Thanks for the comments paragon, I will add tabs to the cockpit and try to make the instructions as straightfoward as possible. Also for the intake, what you did was right, assemble 20 - 24, and then parts 25 - 26 goes into the inside (colour side facing in). At last attach 49k as reinforcement. The whole intake then goes on to the next section of the fuselage. Attach 27 and 27a to 49n, and then this goes on to part 9.
thanks again for pointing these out
i to all
sorry for not add more progres on this weekend
but i pamiss today add some more
well for now i not found any problem on the cocpit parts (not finsh it yet)
and i tack a brack from the cocpit (not like smole parts :) )
for now i start with the fishleg part i only cut them for now
nezard i like the instraction i tihnk thar more than ok
ok my friends
for tonight i finsh cut all the fishleg parts
tommarow we start make it
i found that is we can add some mark on the part that shuld to be cut from the main part that will be helpful :)
ps
i am shure after the test built i will make also the finsh model
ok ppl
on the last 2 days i work on the fishleg part
for now thay all cut out and glueing with the strip
for now i conect the part from the ebegain to the cocpit
and its all looks realy nice and conecting fix
my work not so clen coz its only a test built i whan i fish it i going to make a new clen 1
for now i not found any hard part exept the outline
i will add some pic soon
