Help look like pepakura has gone crazy
CrimosnBronxs
88
Ashington UK
Help look like pepakura has gone crazy on me
I have unfloded a model of starscream g1 cybertron ship
and it's has doubled it
When you loook at the model you can see a gray model and the color under it
I thought at first it was fliped till i unfolded it and found the 2nd model
now it is doing it with a few other ones I have unfolded and i have no clue as to why I know the mesh in 3d max is only one part so how comes pepakura is turning it into two or is it something i am doing wrong
I need help
The model is greyed because the normals are flipped. It is possible that there is a duplicate model as well (the flipped one likely).
I'm not familiar with 3ds max though, so I can't help you there.
You have double the faces because 3dmax renders backfaces, which are counted as separate faces in Pepakura. I do think that there is an option to turn those off in Max though.
Did you try to remove the double vertices in blender ? by pressing Tab to go to edit mode the press W and choose select remove double vertices
