foamboard Enterprise-D
spaceagent-9
Right Hand Man and Confidant
3,235
3,713
65
pheonix
Reactions: Rhaven Blaack
facebook hijacked me right when I was working on paint, and then downloaded trojans, I had to run my security right away. I have warned everyone I have on messenger, and I have heard others complain during the last month that the same thing has happened, or that they are having problems.
Have to keeps tab on this one.. that's an extreme amount of work for what his end result will be. Each to his own , and a new way of working out a concept, and we should gain by the effort he is putting forth.. I want to see this thing fly!
I used to do that in steel blocks to make mold cavities using a CNC machine. Very tedious, eventually, you would use a Ball End mill, and when the scallops were as small as you could get them, you would polish them flat with an Ultrasonic sander that vibrated your teeth lose, until you obtained a mirror finish, then, of course, you had to make the plug, the same way, but it's negative, out of Graphite. Horridly tedious work.........
Thanks for mentioning that! You reminded me of a graphite thread material, simular to kevlar that can be used with epoxy, loomed lose enough for curves on surfboards that might be nifty enough to make 3-5 foot long enlarged paper starships!
Reactions: zathros
