Flex track and foam
Tim K
100
Stoney Creek On. Canada
What is the best method for temporarily installing flex track on foam.
I want to try a couple different ideas that involve using flex track for making large radius turns.
Thanks
Tim K
never tried it...but...how about double sided tape? Or that double sided foam tape?
kevin
Tim
I use "tee" headed pins, available at office supply stores, and push them down through the little holes in the middle of the ties. If you want to try rolling stock over the track use track nails. They will hold fairly well for testing unless your curve is so tight that track tension will push them out.
Stump7
