Digitrax and BLI
spitfire
3,448
Toronto, Canada
www.parkdaleyard.com
I just found this out today and thought I'd pass it along. If you have the Digitrax Zephyr and are having trouble programming your Broadway Limited Imports loco, there's a reason and it's NOT YOU!
The Zephyr (unlike the other 2 Digitrax systems) doesn't program on the main. The power output to the prog. track is limited and doesn't put out enough juice for the BLI chip. So basically, if you have a Zephyr you can't program BLI engines. I had written to BLI before I bought my Zephyr and they told me it would be fine. Guess they were wrong.
The nice DCC expert at the LHS walked me through all of this, and we ended up using their Empire Builder to program the engine. Obviously we didn't get into the CVs, just gave it a 4-digit address, and then tested with the Zephyr to make sure it could acquire the address, which it could.
Another thing he told me, and you can take this for what it's worth, is that BLI decoders are not NMRA-compliant.
Val
:confused: :confused: I have a Digitrax Zephyr and two BLI engines, one a 4-8-4 Northern and the other an E7A and also I do have the mentioned ( above post ) "Power Pax". I used the Power Pax to program the "Addresses" to both engines, but I programed the rest "On The Main" with no problems. In fact I've never had any problems with the running of either engine ( of course I lubed them both after I tested them out of the box. ). I also have "RRampMeter" from "Tony's Train Xchange" which reads my DCC voltage at 13.7 volts the entire layout. Maybe the "Zephyr" or its power supply you refer to is not produceing enough voltage to the track or a bad track connection somewhere ? :confused:
Other than that I havn't a clue. :(
That's exactly the problem - the programming leads from the Zephyr don't put out enough power to program a BLI, as I said in my original post. Sounds like the booster is the way to go.
Val
Val
Then it's "Power Pax" time. :thumb: Sure works for me. :)
I know this affected the earliest BLI 4-6-4's, I have an early one and had some trouble programming it because of the power problem. (I couldn't get it to take a 4-digit ID no, but was OK with two-digits for example.) My understanding is that this has been 'fixed' by BLI on later models?? I also have a heavy 2-8-2, had no problem programming that with my Zephyr on the programming track.
