And another UHU02 X-WING build
lyter1958
Esteemed Member
Jan 19, 2015
478
964
68
Bristol,Vt
thought i'd give UHU02's x-wing a go. i see that nero_on_fire is doing his build also, this is gonna be fun. i went to my local office supply store and had them print it out on 60 lb 11 x 17 paper. 8 1/2 x 11 was too small for me to work with( yea, i know, chicken..:)). been working on it off and on for a little while and it's a amazing model to say the least. so's here are the pic's of what s going on xwing 006.jpga old piece of a backscracher tube came in handy punching out the red dots.xwing 007.jpgall cut n ready to goxwing 008.jpgfront section done.
found a few of the pic's that i "lost" but the rest are gone.pic's 3 and 4 parts had a black dot i added to make it look better. well, to me at least it does:)
yea, i know i go fast. i gotta slow my pace somewhat. but i sit there and say to myself"i'll just do this one section----" and then i look and 'crap' i did 4 sections.. i get into a groove and just space out working on it. it's just so damn fun doing it.:animated:. i just want to build--and build--and build........umm , i think i might need help:nailbiting::hammerhead:.
Reactions: zathros and bigpetr
Go for it, the sooner you're done, the sooner you can play with it!! :)
ok, more pic's.. this is a blast to do. it's really a shame that so much on the detail is hidden inside the body after it's in place, but i know it's there and i can point it out to other people ( if they look at it)..and yes, i did slow down ...a little bit...on the build. xwing 026.jpg case in point on detailxwing 027.jpgnice small rollingsxwing 028.jpg can just make out "danger" on the sides of the tubesxwing 029.jpg all in place
and a bunch of more small parts added. pic 2 was fun to cut out, and then rolling ... i could not have done this at the normal size..
Study this pic, and my suggestion in the pics underneath. I think this would add great detail to your model. :)
viper-jpg.149275
The suggestion is what's important, use UHU outside piece, but cut out the hole, Cut out the very center, and slip it into the whole that's left. Making it look like a vain with blades, again, using UHU's piece, but adding real vanes, angled, and I would mount them to a small tubeI for support. Glue that in, and it will make the model "POP", as this piece does not really make sense. This would give the appearance of it being able to spin, and add depth. My Render is for reference, I made that quick and dirty, to try and explain what I was saying with a pic. Just a suggestion, as you are really early on. ;)
fan-alt-jpg.149276
Reactions: Rhaven Blaack
i see what you mean. there are left over parts on the sheets that i've thought about using here and there to add something to it. thanks for the tip!!!:King:
Reactions: zathros
Just a way of making it pop, and adding some realism. No one else has done it either, so yours will be unique, in that sense. :)
Reactions: lyter1958
