22 guage wire ok for feeders
basementdweller
76
SW Ohio
I am using HO scale, DCC. I was using 20 guage for my track feeders and now I need more wire. I have plenty of 22 guage solid wire, will this be heavy enough? I have been running a feeder to each piece of flex track.
Thanks
#22 is fine for feeders, assuming you are only using it from the rail down to a bus wire below the roadbed, say no longer than 6". Particularly if you have feeders frequently, I like to feed every rail tho that may be overkill. Voltage drop over short lengths will be insignificant. Your bus wire should be heavy, I use 14 gauge.
Gary
Gary
Actually it isn't overkill. You don't have to have a voltage drop to need frequent drops. If you don't have a feeder soldered to every section of rail, you are asking a rail joiner to carry the power from one rail section to another. Rail joiners make mechanical connections, but are lousy electrical connectors. If you use a feeder drop for every rail, you'll have good reliable power for the entire layout.
All too true Russ, and the reason I feed each rail. But sometimes I'll solder a feed to a joiner which is in turn soldered to both rails it joins. In that case you can have feeders every other joint, leaving the other joints unsoldered.
Gary
