test post, moderator controls-1eit title test
This is to try out controls, like deleting your comment, I'll show you, wait, this is his test thread, shucks!! I miss out on all the fun, get back to work DanB!!! :)
thread tools, edit, edit title. no delete or any other tools. am I looking in the right place? should I pee on it?
Pee puddle clean up for post #9 (EDIT skill test)
Click on the box under this post next to my name, when you do that, many options will appear.
Select "Other Actions", on the drop down Menu select "Unapprove", then click "Go". The post will still be visible, but only to you and other moderators, it will then be "Unapproved". On that drop down menu you will see other options, you can do them all, but don't delete, I want to see it.
under your last post all it says is {Go to First Unread} I can post a print screen if you want of what I see.
Post it in----changed----
Well after what I did to you! :)
