I covered up the docking hubs on UHU's mode with the ones from paper-replika's Ranger model (rescaled) because the ones on UHU's model had become to pixellated for my liking at this larger scale. Without further ado, here are the build pics:
MORE progress: The first of the two Rangers! This was my 3RD TRY at attempting to build this thing, but I'm finally satisfied with the result:
View attachment 139671 View attachment 139672 View attachment 139673 View attachment 139675 View attachment 139676 View attachment 139677
I had a lot of trouble attaching the U-shaped "wing to the body. I ended up building the "wing" out of two layers of paper to provide more rigidity. I then printed an extra copy of the front half of the ranger and cut out the gray triangles that show the position of the "wing". I left tabs on them and glued them into the "wing". Be careful here, as these line up with the bottom corner at the bend in the wing and the front end of the triangle does NOT line up with the front of the wing. I'll post pics when I build the next Ranger in a day or two, so that you can actually have a clue at what I'm talking aboutIs there anything to take note of with regard to building the Ranger? It must be something tough/weird if it took you 3 tries.
I had a lot of trouble attaching the U-shaped "wing to the body. I ended up building the "wing" out of two layers of paper to provide more rigidity. I then printed an extra copy of the front half of the ranger and cut out the gray triangles that show the position of the "wing". I left tabs on them and glued them into the "wing". Be careful here, as these line up with the bottom corner at the bend in the wing and the front end of the triangle does NOT line up with the front of the wing. I'll post pics when I build the next Ranger in a day or two, so that you can actually have a clue at what I'm talking about![]()
