Bring on the Kaiju's!
Cybergrinder
Member Extraordinaire
Jun 24, 2014
2,403
4,063
50
Johannesburg, South Africa
Ok, I started Striker Eureka from the movie Pacific Rim over the weekend.
Let us just set the mood first....
:fight:
the template is from paper-replika, and as usual for Julius' work, a very nice template to work with!
I started with the recessed parts which came together nicely
The I attached the flanks and the upper part of the chest to those pieces;
And stuck them together!
The lower part of the chest was then attached, then the back
Then, I managed to drop my knife into the body :banghead: while trying to knock out a dent which resulted in some "open surgery" (i.e.: cutting open the back) to get my knife out.
I didn't have the camera nearby while I was building the head, but, here is the completed head attached
I'm going to see how it looks before I choose how much greebling (if any) I do
It's one thing to see the renders of a model, but, to see the actual build...So much better!
Pacific Rim is one of my all time favorite movies. I cant wait to see the rest of the build progress.
Revell-Fan - What weight do you build with?
I have to admit, the 80 is a bit flimsy, but I'm going to fill the bigger parts with the ultimate internal support substance.
Bucket loads of bog roll.
And I was mucking around with the camera last night...
Thank you JJ Abrams for scarring me for life & messing up the Star Trek franchise....
Reactions: Rhaven Blaack
If you spray the inside with a layer of construction foam, it will stiffen up tremendously, and all you need is a thin 1/8th in layer. Looking good!! :)
Reactions: Cybergrinder
So, another weekend, some more building done;
I finished the front of the chest portion;
And does anyone spot my nice new craft knife?! A gift from my birthday, it's very nice....
Then I attached the torso, now the "six pack" section is a bit long so I'm going to wait & see how the hips connect in case there's any trimming required.
Then I started on the "coat tails" (dunno what else to call them.... :)) Here they are completed
And then attached
And here you can see the "surgery site" from when I dropped my knife in the body. (And my son did the same thing!) Fortunatley there's a nice big piece that will cover the "wound" :)
