1:18 Crichton build
ASC Mclaren
883
371
Western Washington
Hiya! I am chronicling my test build of Marcell's excellent Crichton model, from Buck Rogers in the 25th Century. His design is very intuitive and elegant! I did deviate from the design in one area, when building cylinders, I try to avoid an overlapping joint. So I made a tab to lap behind both sides of the joints on the round parts. Enjoy!
Whoops, there you are! Now I see that you have indeed cut out the holes for the arms; from the perspective of the first pic in the other thread it looked as if the circles were still closed. The tab idea is good, I used the same technique on the big one. However, due to the small size of this model I deliberately added traditional tabs to the parts to simplify the build. Great start, pal!
More progress:
:mrgreen::mrgreen::mrgreen::thumb::thumb::thumb::mrgreen::mrgreen::mrgreen:
Go for it, champ!
(I have a little surprise for you in the making! :cool:)
And more:
He's becoming alive! :thumb::thumb::thumb:
BTW, that's a brilliant idea: Skip the wall1wall1wall1 neck and use a pencil instead! It would have saved me MUCH time..! (No, just kidding! :mrgreen::mrgreen::mrgreen: )
0Thank you all for the kind words! Tonight I start on the arms (gulp). I will say that so far, at this scale I have gone with gluing edges and skipping the smaller tabs.
BTW, I just got an excellent surprise from RF!
There will be more. I'm just figuring out the layout of the bridge and will send everything to you. :thumb:
If you have trouble assembling the arms don't hesitate to PM me and I'll send you a revision. :wave:
Finished the arms. In the pictures you'll see my new hole punch :thumb:. That came in handy on this build. I found a6 problematic (may have been my lack of skill in rolling tiny tubes) although a round toothpick (which I use to apply glue) is about the right size. A3 requires patience! all of the arm joints hold well in an interference/friction fit. I did glue thumb and palms in place, as I couldn't find a small enough wire. I may fix this in the future.
Holy frak - it lives!
:eek::eek::eek:
I'm really, really sorry for the small parts... Well, erh, no. Just kidding! :mrgreen:
You are doing a phenomenal job! :thumb:
Jason, you are surpassing my wildest dreams! It's good that you've found a matching rod. I'll add this to the instructions. Use whatever makes your work easier.
