Star Trek XI Enterprise
Status
Not open for further replies.
sidewinder81777
Midnight Modeler
Apr 30, 2009
238
27
33
48
Florida, USA
This is Paragon's new enterprise with a few modifications to the primary hull to look more like the movie. I modified the area around the deflector. Extended the flat bottom further forward, and modified the shuttle bay area a little.
great job ... again :thumb: were there any problems , wiich you had to solve along the way ?
or other builders have to look out for ?
Hi can you list the modifications for me the only thing i can see u refited was bottem ledge of the shuttle bay and the photon torpedo tube lancher
I also extended the flat bottom of the secondary hull further forward and redesigned the forward part of the secondary hull around the deflector
Looks like the nacelles need to be blown up a bit, say to about 145% their current size. The ship's engines in the movie look much 'fatter' than these. Also, I don't believe the pylons should curve quite that much.
But in any case, that's a great build-up! I think I'll have to give it a whirl.
Saw the movie the next day and straightened out the nacelle pylons some :D
Hi, great build!! I've just started also :D, but i've hit a dead end... How did you build the warp nacelles? especially the rear part (the inside of the tube)
Thanx in advance :)
Thanx in advance :)
Honestly I took the end piece and cut out the blue middle portion and kept paring it down until it fit in the nacelle
Yup, just today i did the same thing :P
Here's my build :D i'm only one warp nacelle away from completion goldtoth1
And here are some pics:
160520091234
Finished!!! (almost :P)
So i've just (almost) finished paragon's star trek xi enterprise model (thank you paragon :thumb:) and here are some pics:
Now all i need to do is to build it a stand, and add it to the fleet :D
Thanks sidewinder81777 and paragon
Status
